davep avatar image
davep asked
GX update shellscript specification in sw-description fails
Hello Everyone,
I'm new to the Victron GX device and am starting a journey to create some custom SW for it. I've been experimenting with delivering some dummy content to the device in the form of an update file and have hit a snag. The sw-description specification for my script seems to be bad, but according to any examples I can find, it looks correct:
sw-description:
software =
    venus-version = "20200906142058 v2.60";
    version = "0.1.0";
        files: (
                        filename = "dummy.txt";
                        path = "/data/dummy.txt";
        scripts: (
                        filename = "dummy.sh";
                        type = "shellscript";
I get the following error upon install:
2020-12-10 18:48:30.761547500 Version 0.1.0
2020-12-10 18:48:30.762287500 [NOTIFY] : SWUPDATE running :  [parse_scripts] : Found Script: dummy.sh
2020-12-10 18:48:30.763127500
2020-12-10 18:48:30.763808500 [NOTIFY] : SWUPDATE running :  [parse_files] : Found File  : dummy.txt --> /data/dummy.txt (ROOTFS)
2020-12-10 18:48:30.767148500
2020-12-10 18:48:30.767420500 ERROR core/parser.c : parse : 95 : feature 'shellscript' required for script 'dummy.sh' in sw-description is absent!
2020-12-10 18:48:30.769409500 [NOTIFY] : SWUPDATE failed [0] ERROR core/parser.c : parse : 95 : feature 'shellscript' required for script 'dummy.sh' in sw-description is absent!
2020-12-10 18:48:30.775105500 ERROR core/swupdate.c : install_from_file : 311 : failed to parse sw-description!
2020-12-10 18:48:30.777870500
2020-12-10 18:48:30.778062500 [NOTIFY] : SWUPDATE failed [0] ERROR core/swupdate.c : install_from_file : 311 : failed to parse sw-description!
I think I'm doing what it says is required. Any ideas?
Thanks.
firmware update
jeroen avatar image
jeroen answered ·
ok, you dare... Please don't do such things with a Color Control, you can completely brick it. (Well it can be restored, but involves moving SMD resistors and knowledge what to do). And please make sure you have a debug console..
That said, see https://github.com/victronenergy/meta-victronenergy/blob/master/meta-venus/recipes-support/swupdate/files/sunxi/defconfig#L60, that option is not enabled in normal builds. But you can enable it of course...
Regards,
Jeroen
6 comments
davep avatar image davep commented ·
Jeroen,
Thanks for the pointer. That error makes much more sense now.
So, I can simply ftp stuff over as I develop, but I was trying to think ahead to something more production suitable. If this is not a safe approach, is there a better or "best practice" way to accomplish delivery of add-on SW?
Thanks.
Dave
jeroen avatar image jeroen ♦ davep commented ·
Well swupdate on a Color Control can also program the bootloader / MLO. That is normally not done, but if you manage to corrupt the bootloader it cannot easily be recovered. The other devices can boot from SD-card etc, so they can always be recovered.
But by itself modifying the swu can be done. I wrote it down at https://github.com/victronenergy/venus/wiki/modifying-a-cerbo-swu-file. Feel free to add a text explaining what it is about.
davep avatar image davep jeroen ♦ commented ·
Jeroen,
I'm inferring from the method you show there that the recommended process, in general, is to start with a complete base update, unwrap it, add/modify as necessary, then re-wrap it.
Thanks.
Dave
No, it is not the recommended process per se, it is simply one which works with the existing software. I think you are the first one to consider altering a swu file.
For venus OS we build everything from source with OpenEmbedded, see https://github.com/victronenergy/venus, and the output are the swu files and images. But you cannot build a full image with that since not everything is opensource.
If you don't need the closed source part, using OE would be the recommended process. Extracting, altering and packing again is simply a method which works, nothing more, nothing less.
Thanks for the clarification.
davep avatar image davep davep commented ·
So, after fumbling around in the dark, I finally found the light switch... turns out what I wanted to accomplish can be done directly and safely with venus-data.tgz on a USB.
https://www.victronenergy.com/live/ccgx:root_access
