Johannes Hodne avatar image
Johannes Hodne asked
Smartsolar 100/20 virtual load vs load port.
Hello. I got a smartsolar 100/20 and use the streetlight function for a hunting light, but I need power for an IP camera 24/7 (if battery voltage is ok)
Is it possible to have the load port only protected by the load output configuration, and then control the virtual load with the streetlight function, not affecting the on board load ports?
VE.Bussmart solar set-up helpStreetlight
wkirby avatar image
wkirby answered ·
Unfortunately, these are not separate, so cannot be configured to do separate things.
What is VE.Bus?
