plinky avatar image
plinky asked
12v campervan set up help
I have a 250 watt single solar panel and victron 100/20 smart solar mppt going into 2 x leisure batteries (12v set up) in my campervan.
1. Is it correct to connect the earthing point on the side of the controller to the negative terminal of my leisure battery....
2. I am using the controller with victron app on my iphone.....the controller came with the jump pins 2 and 3 connected (using the connecting block). Is that the best location for normal use with my set up?...
Many Thanks
smart solar set-up help
markus avatar image
markus answered ·
1.) yes, this can be done, but I think it is not necessary.
2.) this jumper is for configuring the disconnect and reconnect voltages of the load output terminal of the charger, you can configure this settings in the victron app too, but you should remove the jumper then.
Regards,
Markus
plinky avatar image
plinky answered ·
Thanks Markus, appreciate the reply. Regards, Ivor
