Bill avatar image
Bill asked
Each time I disconnect/reconnect a device like the BMV or SmartController from the VGX its a new device number on the VRM portal.
Is there a way to keep the device numbers from changing if I am doing some maintenance on the configured devices? Right now its just annoying, but I can see that getting to be an issue in the future where there is history I want to keep in the portal. Thanks, Bill
VRMVenus GX - VGX
Hi @bigbillsd
If you use the same socket for the same device, usually the id stays the same, if you change the input you'll get a new number.
