How can I use one of the relays in the Venus to turn on a fan, when the temperature is 25F higher than the outside air ?
This way it will turn the engine room fan on, BUT only when needed?
@jan-kees, unfortunately there is not currently a supported way to do this; temperature-dependent relay parameters are not available.
Other users have found ways to do this, however, using third-party equipment: https://community.victronenergy.com/questions/33882/for-the-venus-gx-is-there-anyway-to-control-the-tw.html
13 People are following this question.
