Joe_D avatar image
For the Venus GX, is there anyway to control the two relay outputs to start a fan based on the temperature sensor showing a high temperature (or at least one relay)?
Venus GX - VGX
Joe_D avatar image
Joe_D answered ·
I decided to use a 12vdc temp controller for $11.00
https://www.amazon.com/LM-YN-Thermostat-Fahrenheit-Temperature/dp/B076Y5BXD9
Share
Joe_D avatar image
Joe_D answered ·
Thanks, hopefully this relay parameter for temperature conditions will be added soon. Seems like there is demand
2 comments Share
I know that you now have a solution to move forward with, but if you are/were keen, you can easily achieve this with a Venus GX and Node-RED (internally or externally) or Modbus TCP - but nothing off the shelf/fully supported or formally released as yet.
As an example, this is a user interface screen I made up the other day with a Node-RED dashboard - the switches at the bottom directly control the 2x Venus GX relays;
Link to related conversation on Victron Community: https://community.victronenergy.com/questions/549/feature-request-scheduled-virtual-switch-for-venus.html
Link to GitHub ticket and Beta FW file;
https://github.com/victronenergy/venus/issues/378
Anyway.. all the best and have fun! :-)
Mark
If I could program the Venus GX to switch the relays based on temperature that would be ideal. While I am computer savvy, Red-node does not seem straightforward. Is there a step-by-step guide for newbies for this kind of programming ?
Joe
WKirby avatar image
WKirby answered ·
Unfortunately, temperature dependant relay parameters are not available.
Share
