JF Seatern avatar image
JF Seatern asked
How to change settings without disconnecting cables ? CCGX, BMV-700, MPPT - All connected using VE.Direct.
I have a CCGX, BMV-700, MPPT all connected by VE.direct.
Is there a way to connect to the CCGX to configure MPPT & BMV without disconnecting cables?
Would that work using a USB hub, VE.direct -> USB cables and something connected to the hub to connect via bluetooth or wifi or LAN?
MPPT ControllersBMV Battery MonitorCCGX Color ControlVE.Direct
No, you can't configure the MPPT and BMV through the CCGX.
You will need a VE.direct to USB cable or the VE.direct Bluetooth dongle connected directly to the MPPT/BMV to change the settings.
