elvistherv avatar image
elvistherv asked
VE.Bus diagnostics (Quattro->Advanced) menu option crashes CCGX
Navigating on the CCGX Quatttro 12/5000/220/2x75-> Advanced then simply moving the highlighted option to VE.Bus diagnostics crashes the CCGX with no way to make any changes with the buttons on the device or with the buttons on the remote console.
(I have to SSH in and issue shutdown -r now to reboot)
Interestingly if you click the option in the remote console it works fine.
Quattro Firmware: 465
VE.Bus version: 2633465
CCGX Firmware: v2.40
Build: 20191210205929
CCGX Color ControlVE.Bus
tony-c avatar image tony-c commented ·
I have exact same issue. CCGX V2.41, Quattro 465.
Hi @ElvisTheRV and @TonyC, solved! Venus OS v2.42 was released just now.
Thanks again for reporting.
I added the info into the v2.41 blogpost, of earlier today: https://www.victronenergy.com/blog/2019/12/20/venus-os-v2-41-fixing-byd-communications-and-more/
