Installing six of the lithium superpact 12volt 100amp in parallel on our sail boat. What size alternator will be best? Thanks
six of them can take plenty of charge current (up to 300A) Datasheet-12,8V-Lithium-SuperPack-DE.pdf
So, the bigger the alternator the faster you can charge them.
Conclusion: The bigger, the better. ;o)
Regards,
Markus
13 People are following this question.
