louis-p avatar image
louis-p asked
Why is my inverter stopped working although the steady green light is ON?
Hello people,
I have a VictronConnect Phoenix inverter 12V/375. I have been using it for the past 6 months but it stopped powering my electronic device. The green light is ON and steady and I did not overload it, only plugged my 65W computer charger last thing and it stopped. I checked my installation and everything seems to be alright, I restarted it but anything that I plug does not power.
Any ideas of what it could be?
Thanks
Phoenix Inverter
I'm not 100% sure if there is a glass fuse inside for the AC OUT, maybe you can check that.
(the manual says nothing about a fuse inside)
Otherwise you should contact your dealer for a warranty exchange.
louis-p avatar image louis-p commented ·
Hi M. Lange, thanks for your reply. I will check with my dealer then.
Cheers
