fenix avatar image
fenix asked
SSh putty login as?
Hello
i am trying to do a SSH to the raspberrypi.. i am able to connect with my IP adress on the web, i see the remote screen.
i would like to connect with Putty.... the login as is what? what should i enter there? i try many name but cannot connect
Any help would be apreciate
A
Raspberry PiVEConfigure 3remote console
markus avatar image
markus answered ·
And you have to set a root password. Look here if you want to know how: ccgx:root_access
Hello Markus
i have follow the insctruction as mention... but what i am looking is the " Login as" user that i need to use.
i have enter the ip adress in Putty
the second screen is asking the " Login as"
i did root@internalIP the internal IP is the one that i use to log on my laptop to see the remote console
Any help is apreciate
yes it is working tks alot
elvistherv avatar image
elvistherv answered ·
On the CCGX it’s root@internalIP which is I believe running the same OS.
Hello
i used has suggest the root@internal IP but no luck :-(
any help is apreciate
Ahh right the “internalIP” was just meant as a place holder for “whatever the internal IP of your Raspberry Pi is”.
markus avatar image
markus answered ·
I moved this question to Modification Space
