I just have one cable utp rj45. Or can I use the utp rj12 for configuration and in that way I dont disconnect the color control.
Thank you!!
Thank you!!
It is fine to disconnect the Multi from the Color Control when programming the Multi, and to use that same RJ45 cable connected that is connected to the VE.Bus port, to connect to the MK3-USB adapter instead.
In fact it will disconnect itself via software "Multi Blocked", when it is being programmed.
14 People are following this question.
