Pirx avatar image
Eliminate remaining grid usage
I've installed an ESS environment which compromises following components: MultiPlus II 5k (running fw 459), BYD Box Pro 7.5, CGGX with latest SW, EM24. I did all the settings recommended by the compatibility site. In general everything is working fine now .... accept that the system still draws small amounts of power from the grid. Please look at the red arrows on the next graph
What is this and how can I eliminate it? The battery has enough power and load to cover it. Look at the next graph showing the overall status taken at the same period of time.
So how to get rid of the 7% of remaining grid usage?
Multiplus-IICCGX Color ControlESS
Rob Duthie avatar image
Hi
Just set the ESS setting grid set point to a negative number say 20watts power to re inject the ghost power loses back into the grid remember these Victron inverters are not grid meter accurate at all , and can be a bit out in there readings i have found out.
1 comment Share
Thanks for pointing me to the right screw. I will play around with this setting and observe the impact.
