More accurately, it’s 30 “days” which are calculated based on the solar cycles from the PV input, which means some maintenance events such as disconnecting batteries and/or panels will be seen as the start of a new day. So you may have to export more frequently if you do that sort of thing often.
11 People are following this question.
