mei avatar image
mei asked
How do we Balance Multiple Charging Sources on a Yacht
Yacht Electrical Problems
We have multiple charging sources:
  1. Shore Power: Victron Multiplus 3kVA, 240-12V, 120Amp
  2. Solar Panels: Victron MPPT 150/45, 480W panels
  3. Genset: Direct DC, 200Amp Alternator, Balmar 614 Smart Regulator
  4. Engine: Direct DC, 80 Amp Alternator, Balmar 614 Smart Regulator
We have a Victron BMV712 Smart and a Smartguage to monitor the AGM batteries (765 AmpHr).
These have individual charging systems and we find it difficult to balance the system. Consequentially in the morning when the sun activates the solar panels the MPPT charger thinks it’s in Bulk/Absorb but the Shore Power thinks it’s on float. Some cycling occurs as the MPPT tries to take over.
We have been thinking about the priorities:
  1. When Shore Power is on the MPPT is not required
  2. When the Genset is on the MPPT is not required
  3. When the Engine is on the MPPT is not required
What can we do to balance the system?
MPPT ControllersMultiplus-IIbattery chargingoffgridalternator
dc-generators avatar image
dc-generators answered ·
Hello Mei.
You could use some automation to disengage equipment not needed when shore power is connected.
mei avatar image
mei answered ·
Thank you for your answer.
However we have found a switch in the Victron App, VEDirect Smart Mppt 150/45, in settings there is CHARGER ENABLED. When you switch it to Disabled we get a dialog box with
"Charger will be disabled and Battery will stop charging. This is intended for maintenance purposes only."
What exactly does this mean? Does it mean we CANNOT Disable the MPPT for a day? or a month?
What is the acceptable duration? What are the consequences if it is switched off?.
PLEASE a little feedback from Victron would be fantastic.
Regards,
Mei
dc-generators avatar image dc-generators commented ·
If you disable for any duration, all it means is that the MPPT will not charge at all until enabled again.
If you have a different charger when connected to shore power then that will be able to charge in its place.
amcarter333 avatar image amcarter333 dc-generators commented ·
It is a common practice among the maintenance professionals in my area to turn the MPPT solar charger/regulator OFF for various amounts of time from 1 hour to 1 or more weeks. This does not appear to harm the MPPT nor anything else.
Did you learn anything useful about balancing multiple charging sources?
Michelle Konzack avatar image
Michelle Konzack answered ·
Where is the problem leaving as it is?
If the MPPT switch on in the morning and and load switched on on board, will reduce the power (and electricity bill) from the shore power.
