Keen to have the radiation sensor Si-RS485TC Series -integrated with the Venus . Do you have a plannned release date for this update?
I don't think that your going to get an answer about this from Victron, as it just depends on how smoothly things go along the way and if the scope of work is varied.
Also in the community guidelines I believe that there is a note stating to refrain from asking questions related to product or firmware release timing.
But if you're keen to get the IMT irradiance sensor going now, then maybe consider running the latest Venus beta firmware that already supports it - I have one running in my system and it works great!
Example VRM log from today (with temperature and wind speed hidden to reduce the clutter);
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
9 People are following this question.
Recommended resource to look at for adding to the Venus GUI?
Looking for old Doc "VE - Interfacing with the Phoenix Product Range”.
IMT Irradiance Sensor - Venus OS / Raspberry Pi - Not Connecting Properly
Fixing "dead" Multiplus-II GX / Applying nanopi installer image
OS Releases: Where are they? Supported vs non-supported? Normal vs Large?
