merle.peter@gmail.com avatar image
What Pylontech battery parameters are visible on the VRM?
I'm considering getting a set of 4 Pylon batterys for my Multiplus 5000/48V . I have a Venus GX device and am wondering if you have visibility to the internal temperatures of the Pylontech batteries ( either globally or individually ) and do you have individual SOC values for each of the batteries ? Can you add more than 1 string ( each up to 8 batteries )of Pylonbatteries to a Multiplus/ Venus system all being controlled via CAN-BUS
MultiPlus Quattro Inverter ChargerVenus GX - VGXPylontech
merle.peter@gmail.com answered ·
Thanks, is the SOC the SOC for the master battery ( which should be synconised to the others ) or is it an average of all the individual units in a string ?
1 comment Share
I believe it is just the "Host" first battery. It also ensures the Slaves are kept at same SOC.
safiery avatar image
safiery answered ·
Further comment: You can have 2 strings into the 2 CANbus ports. However, "Synchronise the VE.BUS" SOC may only link to one string. The battery appears as a "Battery Monitor".
Share
safiery answered ·
Peter, we use and sell Dyness Batteries which are very similar to Pylontech. They communicate on CANbus in the same way with the same appearance as Murraynated shows above. To answer you question of what data is visible. There are 5 parameters we see on the VRM , screenshot below:
The Battery temperature is from the first "master battery" in the cluster. We use SOC for assistants.
  • Battery SOC (State Of Charge)
  • Battery Voltage and Current
  • Battery Temperature Sensor
  • BMS Charge and Discharge Limits
  • Battery Summary
Share
Murray van Graan avatar image
Murray van Graan answered ·
Hi, you could add more than 8 batteries but will need a low voltage hub from pylontech to connect multiple strings on the same CanBus. As for the info available from it, some of it available via the advanced tab in VRM, and the following as per screenshots from remote console
You can’t see individual SOC’s, I suspect pylontech keeps all connected batteries at the same SOC
Share
