glennh avatar image
glennh asked
No switch over to ‘charger only’ and ‘shore power’...there is a ‘click’ but no charger output nor shore power...just goes dead. Unit is a Phoenix Multiplus 24/3000/70 - 16...shore power coming into the unit but no output...any ideas?
battery chargingcharge controller compatibility
Justin Cook - Bay Marine Supply USA avatar image
Justin Cook - Bay Marine Supply USA answered ·
@GlennH, what else do you have on your system? Remotes in particular - do you have a CCGX, Venus, DMC, or another remote? If so, have you confirmed that the MultiPlus is set to "On" on the remote? The front switch operation will be largely overridden by commands issued by a remote (with some exceptions), so the first place to check when experiencing this sort of thing is that 1. the remote is set to "On"; and 2. The connection between the MultiPlus and the remote is good.
glennh avatar image glennh commented ·
Hi Justin...apols for late reply. I don’t have any kind of a remote.
Could it be that there is a still an issue with the ‘remote’ side within the unit? Bizarre that there is an audible ‘click’ when I go from ‘On‘ to ‘ChargerOnly’...but at that point the unit goes dark...no charger nor shore power coming through.
Apologies, I’m pretty ignorant when it comes to electronics.
