dannypm avatar image
dannypm asked
PowerAssist on Multi 24/3000/70-50 not working
My MultiPlus 24/3000/70-50 with firmware 2610422 when connecting a 1.5kW load it disconnect the Mains and switch to inverter mode and using solely the batteries.
The PowerAssist is enabled but it doesn't seem to work.
How can I get the PowerAssist working? Is the firmware a culprit?
Thanks in advance
MultiPlus Quattro Inverter Chargerfirmware updatepowerassist
Paul B avatar image
Paul B answered ·
First of all I would upgrade the unit to the latest firmware using a MK3 usb to VE bus unit then see if the problem still occured
