casper avatar image
Tank level sensor for deep water tanks - Venus GX
I'm using a Venus GX and would like to incorporate tank level sensors for our domestic water tanks. The tanks are around 2.5m deep and I would like to be able to use the tank level sensor input of the Venus GX to determine the volume inside the tanks. I've not come across any sensors that can cope with this depth. Does anyone have any options?
Thanks everyone.
Venus GX - VGXtank monitor
safiery avatar image
safiery answered ·
Good Morning @Casper, We provide tank monitoring using a differential pressure transmitter that is no too expensive. https://www.safiery.com/tanks It is a 0-5V output, however, we presently have a project to simply convert this into 0-180Ohm range. If you send your email address, Ill reply when the project is complete. Thank you. bruce.loxton@safiery.com
safiery answered ·
@casper I should add that we then order the 2.5m range for the sensor.
charles-riley avatar image
charles-riley answered ·
I'm using the LevelPro Sentinel Remote tank level monitoring device for a long time without any trouble and also the support team is very helpful. So you can check this device from Icon Process Controls website: https://iconprocon.com/product/sentinel-remote-tank-monitoring/
raymiller avatar image
raymiller answered ·
I currently use a pressure sensor (located at the bottom of the tank plumbing) on a 20ma current loop (industralia quality). I think I use 1bar FSD but lower pressures would give you more resolution. These are also very usefull for water pump controllers as they are fast acting and very precise.
Victron is working on a 20ma current loop interface box which is in the prototype stage I believe.
Has there been any progress on this?
Hi, our 4-20mA interface box is completed and available for a while, its the GX Tank 140.
Good discussion about what senders to use with it is here:
https://community.victronenergy.com/questions/74302/cerbo-gx-water-tank-level-sensor-recommendations-n.html
