geomz avatar image
VRM solar temperature source
Under “System Status in VRM” in the “Solar Yield” quadrant/box of the dashboard there is a temperature number listed there.
Where is that temp sourced from?
Directly from MPPT controllers? If so, which one if multiple?
Area temperature based on weather reporting and stated location of site in VRM?
Other?
Thanks.
MPPT - Solar Charge Controllersolar
Strange that you should ask, as I just questioned the same thing.
I am sure that the MPPT unit is warmer than the 1 degree Celsius that is displayed in the image.
Hi all, its the temperature for the configured location; provided by a online weather service
;o)
Share
ghostrider avatar image
ghostrider answered ·
@mvader (Victron Energy) Does that only populate when there is a GPS fix?
3 comments Share
Nevermind! Did a test... Answer is yes! Manually setting the location doesn't work!
@Ghostrider that is not the case. Manually setting the location in VRM should work. Just checked your instance, and it reports the weather OK for me.
ghostrider avatar image ghostrider Teun Lassche (Victron Energy Staff) ♦ ·
hmm..I had the weather previously set manually and it only showed N/A for the first few days ...then I plugged in a GPS I found and the temperature came alive within minutes. Either way, I'll leave the GPS in place since its nice to have anyway.
Dave avatar image
Dave answered ·
Thank you mvader
Share
