seamaster avatar image
seamaster asked
Quattro two will not Restart from Cerbo GX
I have Quattro II that is working perfectly well and is being detected and controllable from the Cerbo GX. The problem happens when in the evening I turn off the Quattro, so it does not use energy and I want to prevent it from making buzzing noise which I think is normal for those units. Anyhow, in the morning when I try to turn it on from the GX, it will not turn on. I will go to my phone Bluetooth app and I see it stuck and saying “initializing “. (See picture below. )The only way I have found to re-enable it without going to the physical switch is to go to the Bluetooth on my phone and toggle it off/on from there. Once I do that it eventually comes to life and I have full control on the Cerbo GX again.
Does that happen to somebody else and is there a solution for that problem?
cerbo gxVE.Bus Smart DongleQuattro-II
Alexandra avatar image
Alexandra answered ·
@Seamaster
That is not a cerbo screenshot but a ve bus dongle screenshot.
Is all the firmware on all victron devices up to date? Remove it from the smart network you have it attached to and try again.
seamaster avatar image seamaster commented ·
I don’t think I mentioned it is Cerbo GX screen shot. Providing this screenshot was the best way to indicate what’s going on.
All devices are up-to-date with their firmware .
When you say remove from the smart network, what do you mean remove the dongle from the smart network?
Cerbo GX product page
GX family product range
Cerbo GX & GX Touch datasheet
Cerbo GX Manual
Venus root access document
Quattro II Product page
Quattro II Online Manual
Pre-RMA bench test instructions.
