tdcw avatar image
tdcw asked
BlueSmart IP65 to activate Orion-TR smart
Hi everyone,
I have a VW Transporter with a smart alternator and an AGM starter battery.
I charge the Lithium leisure battery using an Orion-TR Smart 12/30 while the engine is running.
My question is: When I'm camping, can I connect a BlueSmart IP65 to the starter battery and let the Orion-Tr Smart charge the leisure one as it sense the correct input voltage? Are there any reasons why this shouldn't be done?
Thanks!
battery chargingorion-tr smartleisure batteries
Justin Cook avatar image
Justin Cook answered ·
Yes, but the Orion-Tr Smart can pull more current from the start battery than any IP65 charger can supply, and considering the inefficiency of the Orion and losses in the circuit, it's not the greatest solution in any case.
It would technically work, but you might end up with a more depleted start battery than you started with, and lots of power wasted as heat. Why not just connect the IP65 to the leisure battery instead?
