michaelroemer avatar image
michaelroemer asked
Orion Smart 12/12-30 isolated not properly charging / input voltage drops
I had a Orion Smart installed on my Campervan to charge a Smart Lithium 12V/160Ah battery. My basic vehicle is a 2020 Fiat Ducato with an 'intelligent' alternator. When driving with a constant speed the Orion did not start charging as the input voltage was quite stable at 12.2V and thus constantly below the start voltage of 14V. I then changed the settings so that the Orion will start charging at around 12V input voltage and it did. BUT as soon as the output voltage stabilizes the input voltage drops to around 10.2V, the Orion cuts off, input voltages raises, Orion starts, input drops and so on.
What can be the cause of this? Is there something I can check? I would be really happy if someone had an idea how to correct this!
Thanks a lot, Michael
battery chargingorion-tr smart
wkirby avatar image
wkirby answered ·
There is certainly a problem with the wiring leading up to the input of the Orion.
Either there is a fault or the circuit is not up to carrying 30A without the significant Voltage drop that you can observe. This much Voltage drop is really bad and need to be investigated.
Please have the wiring checked or ensure that the circuit and its wiring is up to the task for carrying at least a 30A load.
michaelroemer avatar image michaelroemer commented ·
Hi wkirby, thanks a lot for the answer. Besides the wire size (which I believe is fine as it was done by a electrician), what could be the issue? Thanks a lot, Michael
Bruce Johnson avatar image Bruce Johnson commented ·
i have a very similar problem. And I am certain that the wiring is fine. What else could be the issue?
kevgermany avatar image
kevgermany answered ·
You need to find out what's causing the input of the Orion to drop so far. Starting point is probably the electrician. Ask him to explain where the feed to the Orion comes from and why.
I'd guess the alternator is cutting the output because it's not seeing the load from the Orion.
