steinkare avatar image
ArgoFet energize input fuse
Hello,i have installed an argoFet 200A with 2 output.
Energize input is powered by 12V from a fuse directly connected to startbattery, after mainswitch
I dont find ignition power that the reason i powered directlys from mainswitch,
This fuse blow almost every time i stop the engine,,,
what can be the problem, is there anybody having this problem?
Best regards
Stein Kåre Nilsen
Brønnøysund
Norway
battery charging
Hello, fuse size is 10A, i have tried 20A too, but its the same, it blow anyway, i think it is jnder stopping engine it happend,
Maybe a solution is to find ignition power and connect via relay, so when engine stop, the power on energize input disapppear...
Share
Margreet Leeftink (Victron Energy Staff) avatar image
Hi Stein,
The maximum current is 20A, but this is usually only there during a short moment, and it is not present for long enough to blow a 5A fuse. The normal running current is much lower.
What size is your fuse? and are you using a slow-blow fuse?
Also see this post: https://community.victronenergy.com/questions/17595/argo-fet-energize-current.html
Share
