Hi everyone,
so, the charger does 14,4V.
All loads are designed for 12V.
Do they blow up?
I'm a noob, have mercy.
Hi everyone,
Do they blow up?
It depends, 12V DC equipment that is designed for mobile applications such as in boats, vans, RVs, caravans will normally be designed to take that wide range of operating equipment. All the Victron 12V equipment will be OK.
However, if you have a domestic appliance such as a router that has a 12V DC adapter from AC grid power then this is only expecting a 12V supply so you should not connect it directly to your DC system, you will need a DC to DC converter to change your 11.5-14.5V DC to regulated 12V. If you have lots of loads like this you can.use a Victron Orion in power supply mode.
I was hoping for that answer. :) So, I will give everything a try.
Thank you!
Blue Smart IP22 Product Page
Blue Smart IP22 230v datasheet
Blue Smart IP22 120v datasheet
Blue Smart 120v manual download
Did You Know? - use the blue smart as a power supply (video link)
History and Settings for Blue Smart Chargers in Victron Connect (video link)
43 People are following this question.
