josh-costanza avatar image
josh-costanza asked
Can you independently charge 2 LiFePO4 Batteries on a Blue Smart IP22 12V 30A 3 Output Charger?
I have 2 -12V LifePO4 batteries with the same amperage (270 amps each) but different charge levels. The Blue Smart IP22 says One or Three outputs. I want to charge these batteries independently but the charger only appears to charge the first output and the VictronConnect app only shows the status and history for that first output only. Does not look like you can charge using only 2 of the outputs.
I know you can do parallel charging off 1 port but my batteries have an internal voltage disconnect that is making it problematic. I bought this charger thinking it could charge up to 3 devices but it appears its 1 or 3 of the same chemistry. The manual has no mention of this.
Any confirmation of how the outlets work or suggestions on how to get 2 to charge and track status on individual outlets?
chargerbluesmart ip22
