Hi!
Can I add two MPs to my old one to create a 3 phase system as long as the Part no# of all three MPs is the same?
Thank you!
Hi!
Thank you!
Hi @Dominik Feser,
This situation is explained here - https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
The safe answer is we officially support when the 3 units are same purchased at the same time.
Mixing older units sometimes works though, but then you need to go into it with eyes wide open that it might not. I would never do this for a customer, but I might try it for myself, and then not complain (or at least explain very clearly the situation) when things aren't working perfectly.
121 People are following this question.
