juha-aholaakko avatar image
juha-aholaakko asked
Which DC to Dc Converter to use for outboard engine alternator. Yamaha F60 A 12-Volt 16-Amp
What DC - DC converter do you recommend for the boat, the engine is Yamaha's F60 (Year:2009), which outputs 12V and 16 Amps.
I now installed 12V/12V 18A, but when driving at low rpm, the DC-DC converter try to charge but after 1-2 minute's reports, low input voltage or motor stop detected. And also when driving with high rpm, loading speed jumping between 0-18A.
What charger setting should I use from the Victornic app?
I am trying to charge Sunwind's 100Ah lithium battery with a DC-DC converter
Lithium Batteryorion dc-dc
