Connected Multiplus inverter to VE Panel according to diagrams. All voltage going into from battery read good. There's no voltage on AC 1 on inverter or VE Panel. Any ideas?
Its MultiPlus 24/3000/70-50 120V connected to Victron VE panel.
The VE Panel comes preconfigured with all cables color coded so its kinda hard to make a mistake, Connected Battery cables to VE Panel and from VE Panel to Inverter batt inputs - as well as AC in and AC out. Connected MPPT to Battery Bus bar in the VE Panel and Solar panels to MPPT - its a simple set up.
I get all DC side readings on the battery side and Inverter side (26v) but i see no voltage at all on AC out. I have not connected a on shore power to AC in yet (Generator)
Thank you Duivert NL
Can you please make some pictures of the devices and the wiring?
Thanks Matthias. This is the set up. VE Panel is the section beneath the inverter. Comes prewired and i followed the schematic from Victron, I have no power AC reading from either AC Out 1 or 2 - there's voltage in DC section of the inverter (26v)
When i power it on - it buzzez and makes clicking noises, I have disconnected the AC load in this picture (next to the label GEN INPUT)
39 People are following this question.
