I have had this inverter running for a year now. recently turned it off to change the battery and then firmware updated it using Victron connect... when I plugged in AC input/mains the inverter switched to Bulk charge mode but wasn't seeing any grid input on GX-touch.
But I can see AC Out putting in power to the system (its like the system is registering AC in as AC out)
- I have tried both AC IN-1 and AC IN-2 same result
- AC input current limiting is not working either
![1710782081076.png](/storage/attachments/73058-1710782081076.png)
