Can I connect these two DC/DC converters in parallel? I want a redundant 24V system.
On the output side, yes.
I assume you have a 12V and a 48V feed. You will end up with a negative connection between the two systems unless you use isolated converters.
Victron DC to DC Converters Product Range
__________
39 People are following this question.
