erikj725 avatar image
erikj725 asked
IP-43 charger shows positive charge battery current with Cerbo but also output current flow
I have a pretty simple system (Smart Shunt, CerboGx) and recently replaced my old non-Victron charger with an IP-43 Smart to accommodate lithium batteries. Smart Shunt and IP-43 are connected to Cerbo with Ve.Direct cables.
  • When the charger is charging, Cerbo shows a positive current on the battery and positive watts, but the current "flow" dots are moving to the DC Power box and not into the battery.
  • When the charger is off, the battery shows a negative current and the flow continues moving to the DC Power box.
  • If I unplug the Ve.Direct cable from the IP-43 and the charger is charging, the flow dots move toward the battery like I expect. The old charger showed the same as does my non-Victron solar controller.
What am I missing here?
cerbo gxPhoenix Smart Charger ip43
@erikj725
Is the smart shunt a dc meter or a battery SOC device?
Do you have something measuring dc power as well?
erikj725 avatar image erikj725 Alexandra ♦ commented ·
The Smart Shunt is connected right after the battery to measure all the in's/out's of the battery. So shouldn't that track everything?
