mw-solar avatar image
mw-solar asked
ET112 over LAN
Hi Guys
New here.
First of all is it possible to recognise an ET112 over a LAN network?
I am sure I read it was an option via Modbus TCP/UDP devices but cannot find the document again.
I currently have a ET112 ESS Grid Meter setup via a ZigBee but would prefer a solid connection as it frequently drops out.
I'm aware I could run a hard wired connection, but I am looking at options as the WiFi RSSI to the system location is very poor too.
My SWA AC feed to the system is good, but I am trying to avoid running another 2x SWA cat6 if possible as they run underground, and instead sending a LAN network out there wirelessly, or via a powerline adaptor?
I've installed 10 or so Victron ESS systems, this one is for my own property, and I am quite keen to experiment on the network side of things if it's possible as I have little experience on this side of things.
I'm aware Fronius and apparently SolarEdge can be setup in a similar way over network but I normally wire AC PV through a separate ET112.
Really just a learning curve and looking for advice and to expand my knowledge moving forward on the network side of things.
Any advice much appreciated
TCP IP Networking
Duivert NL avatar image
Duivert NL answered ·
It doesnt have lan, so no
You could use rs485 to lan and lan to rs485 transceivers, but if it will work…
An other option is the EM24 ethernet version
mw-solar answered ·
Thank you. Annoying as the ET112 has RJ45 ports.
I will give the transceiver option a go and update if it works.
Galin Radoslavov avatar image
Galin Radoslavov answered ·
RJ45 ports are RS485 only
matt1309 avatar image
matt1309 answered ·
Hi @MW-Solar
You can use RS485 to TCP/IP devices (one at each end to convert from RS485 to IP and then back to RS485). Waveshare sells these, my current setup is using 2 of them to achieve this. Happy to share more details if you go that route.
Or you alternatively I've seen others on here use RS485 to modbus tcp and using a custom driver to integrate.
However if you've not already bought it then a lan based energy meter might be easier/more robust/less points of failure.
