acdc avatar image
acdc asked
Only 2 Milliamperes with Virtual load output TX cable?
I want to use a SSD Relais with my 100/30 SmartSolar and the Virtual load output, but it does not work. I measured 5 V and only 2 Milliampere with my Multimeter on the TX cable. I even bought the recommended Omron G3NA-D210B-UTU DC5-24, but the current seams to be too low. Shouldn’t the TX cable deliver 20 Milliamperes at least?
Battery Protectsmart solar set-up help
Alistair Warburton avatar image
Alistair Warburton answered ·
According to the data sheet the max input will be 7mA at 24V so 2mA at 5V seems reasonable to me.
What is you load?
You cant measure resistance/continuity of the output with a meter it will have to be a DC load at a minimum of 5V.
Al
acdc avatar image
acdc answered ·
Hi Al,
thanks for your response! I don’t quite understand. I connect the TX cable pins to the input of the relay and it does not switch on. So the relay is my “load”, isn’t it?
Kind regards
Frank
