I have a 400AH EG4-LiFePower4 battery. Does anyone have the Victron solar charger and battery monitor settings?
Are these the same batteries? Always refer to the manual if one can be found. They all are downloadable from the site even the warranty, if this is the same battery you are looking at.
The technical part of the manual 3.3.4 table 3.7 states charge voltage range 55.2V~57.6V. 56.0V Recommended.
Spec sheet has all the info you need.
For the battery monitor use the recommended lithium settings as in the videos 1 or 2
40 People are following this question.
