n3wby avatar image
n3wby asked
VE Configure parameters for 24V system
Hi fellow Victron users,
I was hoping to confirm a few parameters from the VE config.
1. General tab:
- What applications would enable battery monitor be used?
2. Inverter tab:
- What Voltages are usually set for the low values for a 24V (25.6V) system? I understand this also depends on battery BMS & manufacturer specs, hoping for a comparison.
3. Charger tab:
- What charge curve is preferred for LiFePO4?
- For a LiFePO4 battery, is this selected via battery type or just checking the lithium battery box?
- Any comparison charging voltage specs for a 24V system?
Please let me know if there are other parameters that I have missed & should consider checking in configuration.
Thanks.
Multiplus-IIVEConfigure 3
We need more details about the system.
Batteries? Other components? What kind of system (RV, boat, house - on-grid/off-grid)? Wiring diagram?
