flyman avatar image
flyman asked
Phoenix Inverter 24/3000 come impostare con LiFePo4
Ciao Gruppo, in barca ho Phoenix Invert 24/3000 e 2 Batterie Victron Smart da 25,6v e 200a/h in parallelo (400a/h) come devo impostare correttamente
• Spegnimento per batteria bassa (attualmente 18.60v)
• Riavvio e allarme per batteria bassa (attualmente 21.80v)
• Rilevamento carica (attualmente 27.50v)
Grazie per il supporto
Phoenix Inverter
klim8skeptic avatar image
klim8skeptic answered ·
@Flyman It is best to read the LBS manual .
It is important that your batteries are protected by a Victron BMS.
And all loads and chargers are controlled by the BMS.
flyman avatar image
flyman answered ·
Thanks for your support, yes I have a BMS V2 connected to the Cerbo GX, but currently the bms only works when the Skylla charger is on, when only the inverter works the bms v2 doesn't work the blue lights are off, I'll have to work more!
