klaus-dk avatar image
klaus-dk asked
3 phase Multiplus 2 system, stop charging and have a strange sound
Hi I have a 3 phase offrgrid(for now) system with 3 multiplus 2 5000KVA. On the output I have a 3 phase Growatt 10Kva TL-x inverter(with 6,5Kw solar panels). I have a 30Kw batterie with 2 JK bms´s(2x15Kw). My problem is that when it is charging from time to time(1 to 15 min.) the charger shots down, making af strange sound, at bit later it starts up charging again.
I don´t get any fault codes, or anything, a couple of times the inverter has shot down because of it.
Do I need to make another configuration, or do you have any ide what the problem could be.
I have installed it as a 3 phase system, and I have installed the PV assistance.
Rg.
Klaus
offgrid3 phasesmart solar charging behaviour
