pierreke avatar image
pierreke asked
How to connect simple two wire lightswitch to phoenix compact 12/1600
Hi there.
I want to connect my phoenix compac 12/1600 to a simple light switch the wires are already there because I used them in a previous inverter.
I have drie inputs on the board. How should I connect it?
Want to turn it on or off.
Phoenix Inverter
Alexandra avatar image
Alexandra answered ·
@Pierreke
If i remember correctly the connections for remote switch: Short left and middle terminal to switch the Multi “on”, Short right and middle terminal to switch the Multi to “charger only”.
7 comments
pierreke avatar image pierreke commented ·
@Alexandra Thanks for your quick reply.
Do I have to change something in the DIP switches? See screenshots of the manual: For the 3-way switch I have to, but… is this a 3-way switch?
Thanks!
Alexandra avatar image Alexandra ♦ pierreke commented ·
@Pierreke
So it has been too long to remember all the steps...
Yes set the dips. Is the unit new or second hand?
pierreke avatar image pierreke Alexandra ♦ commented ·
Second hand unit.
Duivert NL avatar image Duivert NL pierreke commented ·
Yes use a 3 way switch
Center contact or p contact of switch to connection 2 (gnd)
First Contact from switch to connection 1 (charger only)
Second Contact from switch to connection 3 (on)
pierreke avatar image pierreke Duivert NL commented ·
But I only have two wires from the switch. It’s a regular light switch which is installed behind walls. Not easy to change. Is it possible with this?
Ok, you said you have a 3 way too… then follow klim8sceptic advice
Thanks duivert. Wasn’t aware that I said I have a 3way switch ;)
klim8skeptic avatar image
klim8skeptic answered ·
@Pierreke If your Phoenix is an inverter (not an inverter + charger) you only need a switch with 2 contacts.
Connect to on, remote terminals 2 and 3.
Dont forget to set your dipswitch.
Perfect. Thanks for the quick and spot on advice
This worked perfect! Thanks for the help!!
