charly88 avatar image
charly88 asked
Vitron battery protect shuts off on high voltage
I have a battery protect installed, together with a new Lifepo battery. When the battery is near full, the battery protect shuts off.
My guess, that the bms from the battery shuts off on overcharge protection, and this creates a peak voltage in the system.
How I can stabilize the system?
Are there some high voltage protections / Surge arresters that level those peaks?
Battery Protectovervoltage
Alexandra avatar image
Alexandra answered ·
Or you could address the actual problem which is the battery.
Maybe lower the charged voltage a bit from your charge source, or use a slower charge current to mitigate the bms shut down.
You can get 12v DC SPDs/TOVs.
charly88 avatar image charly88 commented ·
Thanks for the idea!
I digged into changing the solar charger settings. Looking good for now!!
Victron BatteryProtect product page
