glosta avatar image
glosta asked
Which product can do a high voltage battery disconnect that I can program/set the volts to my own setting.
Concerning a marine 12VDC system: Which product can do a high voltage battery disconnect that I can program/set the volts at? I'm aware of the BMV-712 relay control function, but already have a battery monitor system in place, and regardless I would also then need a high amperage relay. Is there an all in one product like BP Battery Protect, but used to disconnect any over-charging conditions for my charge bus and possibly with alarms too?
battery chargingBMV Battery MonitorBattery Protectovervoltage
kai avatar image
kai answered ·
Off the shelf? A full featured BMS would do it, like the ones Elithion and Orion makes.
Not sure about Victron.
Victron BatteryProtect product page
Victron BMV battery monitors product page
