simon1111 avatar image
simon1111 asked
Integration of Multiplus 5000, 5KW Generator, and PV System for 3-Phase Power Supply
I hope you can assist me with a project I'm working on in a mountainous area where there is no grid connection available. The project requires a 3-phase power supply. To address this, I have a 100 KVA generator, which is significantly over-dimensioned, and an industrial dishwasher that requires a 3-phase power supply (assuming around 9KW). Unfortunately, the exact power requirements of the dishwasher are unknown.
My main question is about the integration of the generator with the Multiplus inverter/charger. If I connect a Multiplus 5000 inverter and a for example 5KW generator, does their combined output adapt to 10KW, or is it still limited to the 5KW capacity of the inverter?
Additionally, I have a large PV system on the roof with a 3-phase inverter, and the dishwasher is intended to operate primarily during periods of high solar insolation. During times of low solar insolation, the dishwasher can run on the 3-phase generator. Since no other significant consumers exist in the house, can I reduce the minimum recommended battery capacity for the Multiplus 5000? I also have a potential hydroelectric power plant nearby and plan to charge the batteries with it around 1KW continuously, so having a large storage capacity doesn't seem necessary.
Your guidance on this matter would be greatly appreciated.
Thank you very much for your assistance.
Multiplus-IIGeneratoroffgrid3 phaseHydro and Wind Power
