My Powerstation Oscal Powermax 3600 has a solar input of 11 to 150V with a max Amperage of 15A. I have two MPPT controllers in parallel (one 230w panel and the other 2 x 90w) delivering a maximum Wattage of 410 WH.
I've set them to 24V, but they meassure the Solar input @ the powerstation as 12V, so the max Wattage is now around 180WH (12V x 15A). So in a way the MPPT's are too smart (I have a Smart solar 75/15 and a 100/20).
Is there a way to force the MPPT's to deliver a higher voltage? The 230W panel delivers 20V to the MPPT (and the other two panels even 38V)? If I could force the MPPT's to deliver 20V to the Powerstation it would be way better (in practice the combination hardly goes over 300WH, because of the terrible location of the 2 x 90W panels :-)
For now I've connected the 230W panel directly to the powerstation and the other 180W to another battery, but that's not ideal.
