greg-1 avatar image
greg-1 asked
No BMV - no battery warranty?
My potential distributor just informed me, that "the BMV is the basis for a warranty claim for the batteries in the event of a complaint. (No BMV - no guarantee)". Is that true?
The setup:
VICTRON - BlueSolar MPPT 100/50
VICTRON - Lithium SuperPack 12,8V/60Ah
VICTRON - VE.Direct to USB-Interface
VICTRON - Orion DC-DC - 12V->24V 20A
The distributor suggested adding the BMV-712. Unfortunately this is not an option because the system will be used to power an satellite tracking antenna working in 2.4GHz (amateur S-band), so no Bluetooth devices can be present.
BMV Battery Monitorbattery
For my peace of mind, I download the history log from my mppt monthly.
History includes daily min/max battery voltages, charge states achieved, daily pv energy yield. Certainly enough info should the battery need a warranty claim. (now if we could also get daily min/max temp on the mppt log, would be ideal)
greg-1 avatar image greg-1 klim8skeptic ♦ commented ·
Actually I intended to monitor the system with a Raspberry Pi (running Ubuntu, not Victron's OS). But maybe the BMV is also necessary for that, as mentioned in the description of this monitoring software: https://david.mercereau.info/motclef/raspberry-pi/
wkirby avatar image
wkirby answered ·
I really don't think the battery warranty will be affected by the presence or not of a BMV.
It seems to me that your dealer is trying to upsell.
A system like you describe should not need a BMV. The SuperPack has inbuilt protections anyway.
BTW, you could use a BMV-702 or BMV-700 without Bluetooth.
kai avatar image
kai answered ·
Agree, although I wonder the distributor is confusing BMV with BMS (which is kind of a red flag in itself) for a different product. When I got my LiFePo cells, they came with a similar warning that they have to be used in conjunction with a BMS and warranty will need to be supported by data from the BMS (paraphrasing, its been a while)
Presumably as a precautionary measure on the part of the vendor to limit misuse/abuse of cells.
wkirby avatar image wkirby ♦♦ commented ·
I had wondered if there was any BMV / BMS confusion, but as Grg said, the distributor specified a BMV-712, so that cleared up any confusion in my mind.
Victron BMV battery monitors product page
