jjj avatar image
jjj asked
I have a Victron Pheonix Multi plus 12V 2500 VA 120Amp Inverter charger. Overload, low battery, high temp lights on.
I woke this moring to find the Overload, low battery, high temp lights on. Plus the float light is also on. None of the faults are taking place now. Its possible battery was low in the night. I have disconnected all inputs and outputs to see if it will reset, but it has not. Does nybody have ideas on what to do about it please?
victron products
@jjj
Sometimes a reset to factory works. Or a firmware update and then reprogram.
If it does not, then you need to contact your supplier
