I have 10x MPPT connected through USB hub, in the VRM I see just the total of the generated power from the first 4
The sum doesn't include the rest of the units. Any hints?
Check pictures attached
The system sees it as DC power, question is why
What is connected to DC power?
Even in list of devices I can only see the first 4
Victron have always recommended a quality, powered usb hub. 'Inadequate' devices are available aplenty and can give issues like this. Big price differences in the market, but this isn't a bank of phone chargers, it's all-out data. Your 'Last Seen' messages also suggest long term data breaks.
You didn't answer the question about GX type, but there are some that would gag on a data load like that. Often accompanied by Wait or Busy messages. But anyways might benefit from a firmware update if you haven't done so already. A reboot of the GX often helps if something's corrupted.
The usb hub seems the most likely offender to me..
Hi, it's a cerbo GX, everything was working fine before, have latest firmware and tried rebooting without success...
Which USB hub would you recommend?
yes its probaply that, a defect usb hub
the cerbo can max handle 15 VE direct devices, so also check if you dont exceeded that amount
169 People are following this question.
