I/O menu not visible on CCGX - Will it show when a compatible bluetooth is plugged in?
The old CCGX doesn't have any I/O and die to the old hardware the CCGX doesn't support all newer features.
What do you want to do?
I want to plug in a Bluetooth device and connect to RuuviTag sensor for temp and water tank reading
The Bluetooth menu should appear as soon as you plug in a compatible Bluetooth dongle.
66 People are following this question.
