Kees Oomen avatar image
Kees Oomen asked
Bug? Orion XS does not recognize Victron BMS v2
Hi, when I check settings on my cerbo GX, I can connect to my Orion XS device which is connected with ve.direct. I can also control it through the cerbo, so the connection is working.
However, the Orion does not detect my BMS. I am checking with dbus as "/Settings/BMSPresent" is 0 for the Orion XS. And it's 1 for my MPPT (so that one works..)
As a result That causes the Orion not using DVCC (for example when settings DVCC charge limit, the Orion XS does not take it)
I have cerbo gx firmware version 3.20 and orion xs firmware version v1.03 (latest)
- edit: updating cerbo gx firmware to 3.31 did not change the issue
BMSDVCCorion xs
Kees Oomen answered ·
Maybe I should restart my Orion XS, but how can I do this, aside from disconnect from power supply?
Kees Oomen avatar image Kees Oomen commented ·
This did not help
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi @Kees Oomen
At the moment, /Settings/BMSPresent will indeed always be 0. DVCC and the charge limit should work however. We will look into this. Thank you for reporting this issue.
Kind regards,
Thiemo van Engelen
Thanks Thiemo. Just for the record: Manually setting charge limit through /Settings/Set/ChargeCurrentLimit is working, but when trying to do through DVCC is does not take it over.
Hi @Kees Oomen
We are still investigating this, but for now it seems that this is indeed a software problem specific to the Orion XS and Venus. I unfortunately can not give any more information on when this might be solved.
Kind regards,
Thiemo van Engelen
