jwh avatar image
jwh asked
Using Smart BMS 12/200 parallel with DC DC charger
Hi, Is it possible to use DC DC charger (Orion XS 12-12V 50A) in parallel with Smart BMS 12/200 to charge my smart lithium 160ah. I have engine alternator connected to starter battery which is connected to Smart BMS. I'd like to get better charge rate and lifepo programmed charge algorithm from my engine alternator. Does Would the DC DC charger be installed between starter battery and Smart BMS or between Smart BMS and Lithium battery?
BMSorion dc-dc
